Anybody with SLP runners come inside
Old Feb 16, 2002 | 09:13 PM
JAY87GTA's Avatar
Did you hace trouble getting the cold start injector to seal? I've been trying for a month to get mine to seal with no luck. It keeps dropping cylinder 2, don't know if ti's related or not but I want everything else right before I go after it. Anybody? Thanks
Old Feb 16, 2002 | 09:30 PM
DFI79MC's Avatar
Car: 79 Monte Carlo
Engine: 406
Transmission: 2004-R
Axle/Gears: Phord 9 inch/3.90
I have the SLP's and havent noticed any problems yet, I guess I'll have to look a little closer tomorrow
Old Feb 17, 2002 | 10:22 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I have them but, did not put them on yet! The hole looks perfect. (best thing I can say because the top edge where it meets the plenuim the part you see when it is together looks like ****! big bubble holes.) did you check the O-ring seal on the cold start inj. it may have shrunk with age hence it will look good but, not seal try a new one maybe one slightly thicker if possiable and lube it up first. good luck and let us knowwhat happens.
Old Feb 17, 2002 | 03:25 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
I have a problem w/ vac leaks everytime I touch the cold start injector w/my SLP runners.
BD3
Old Feb 17, 2002 | 06:30 PM
JAY87GTA's Avatar
Man, I've tried everything to get mine to seal up to no avail It's becoming really frustrating because I have other problems I can't sort out until I get that right. Anbody else?
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
no green
Jan 9, 2016 09:22 PM
KO1
16
Oct 15, 2015 05:00 PM
Royal_Z
Sep 30, 2015 08:45 PM
