CTS and Fan Switch...
Old Jan 10, 2002 | 07:33 AM
IROCKER's Avatar
I believe I know the answer to this but I thought I would confirm...are the coolant temperature sensor and fan switch two separate units?
Old Jan 10, 2002 | 09:24 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You are correct. The CTS is in the front oif the intake and is used by the ECM to control various temperature dependant functions.
The Fans Switch is in the pass. side head for the 2ndry cooling fan.
Old Jan 10, 2002 | 10:22 AM
IROCKER's Avatar
Thank you. I thought they were both separate units, but I just wanted to double check.
Which one is on the drivers side between the 1 and 3 spark plugs? Can that be the fan switch...I've heard some years had them on different sides?
And the CTS is definately by the front of the intake?...I'll have to look for that when I head there on the weekend.
Old Jan 10, 2002 | 10:50 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
On the driverside head is the sending unit for the temp gauge.
Also, on your '87, on the front of the intake is the Cold Start Injector Thermal switch, don't confuse it with the CTS.
Old Jan 10, 2002 | 10:52 AM
IROCKER's Avatar
Thanks for the heads up.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
