Air foil
Old Jan 11, 2002 | 09:10 PM
91 z28 350's Avatar
Car: 91 Z28
Air foil
I just bought a Air foil off of ebay and i was just wondering when i putt it in do i need to replace the throttle body cover gasket ????
Old Jan 11, 2002 | 09:31 PM
91-ZZ4-Z28's Avatar
If it rips or tares or seems dry replace it. If not it may be ok.
Old Jan 12, 2002 | 03:14 PM
pauls's Avatar
No you do not. Just be careful when removing the cover, and the gasket will be fine. To be sure of a good seal, lightly coat gasket with a coat of engine oil before re-assembly...it will seal great. You should also be able to install the foil with the throttle body on the plenum. I 've got one and it works nice. I think the foil helped . On a built 305 / 350 they are rated at giving 10-12 hp max on the TPIS dyno. In reality on a more or less stock engine, I've seen in print 4-6 h.p. being the gain. To enhance the foil, I also gutted the air boxes and went to K&N filters.
Old Jan 12, 2002 | 04:38 PM
F0xBody50's Avatar
I've got a TPiS Air Foil installed on my TB and it produces a noticeable little increase in throttle response, nothing to brag about, but it helps and was worth the money $46.00 (new).
I also have a partial gutted airbox and K&Ns....
-ONE2FLY
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
