Need to replace fuel injectors on my 1988 305High Output TPI w 5speed manual
Car: Iroc z28 1988 total odo 33.000miles
Engine: 305TPI 220 HP
Transmission: 5 speed manual
What injectors would you guys suggest,
And when under the plenum, what should I replace at the same time to save coming problems.
You can answer here or if you like to
bo@tacticalheadsets.com
Best /Bo in Sweden, Scandinavia.
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: Need to replace fuel injectors on my 1988 305High Output TPI w 5speed manual
Delphi #19 from Southbay Fuel Injectors. TG11 promo code for 10% off.
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
I also suggest the Delphi injectors over the loud, annoying Bosch III. More expensive, but worth it. I'll never install Bosch III on another third gen again.
https://www.southbayfuelinjectors.co...-1986-1992-851
Transmission: World Class T-5
Axle/Gears: BW 3.45
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Engine: LB9 305
Transmission: AT
When I did my 86 Corvette injectors, I replaced the thermostat (180*) , EGR Valve, Fuel Pressure regulator diaphragm, fuel filter, while I had it apart. I knew from the previous owner, it had water in the fuel tank, so I cleaned tank out and removed the injector fuel rail, disassembled it, replaced the O Rings and bead blasted the rust, off the pressure regulator housing. (FWIW I did plugs, cap, rotor, wires, PCV also, but you certainly don't have to do that).
I will be doing the same job, on my 89 IROC Z 305 TPI Vert, soon.
I will take a 30 year injector please.
