Intake Manifold Help
Old Mar 15, 2020 | 06:12 PM
DontBlnkBadWolf's Avatar
Car: 2002 Dodge Ram 1500 Quad Cab
Engine: 4.7 Liter
Transmission: 4 Speed Auto
Just a quick question: What size Torx (Star) Bit is the 6 bolts that bolts the intake to the heads? I thought it was a T-45 but, the T-45 bit started twisting and then snapped in one of the intake bolts. These SOBs are on really tight and I'm sure being 35 years old doesn't help either. I can't heat them in fear of starting a fire, and I haven't found a lubricating spray that'll work.
Old Mar 15, 2020 | 08:35 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Intake Manifold Help
Are you working on a Chevy or the Ram in your profile?
T45 is typical for a 3/8-16 bolt used on TPI manifolds. If you're working on the Ram, look closely at the bolt socket. Make sure it isn't an TP45 or IP45 (Torx Plus).
Old Mar 16, 2020 | 11:46 AM
Engine: 4.7 Liter
I would be on the Ram forums if I was working on my truck.
I would have not said 35 years old if it was my truck, my truck is almost half the age of my Z.
Old Mar 16, 2020 | 04:18 PM
Drew's Avatar
Buy a quality set of torx bits. Use the largest size that fits tight. Clean out the socket in the bolt, press the bit in until it bottoms out. If it gets tight before it bottoms, try the next size smaller or tap it in with a hammer until it's fully seated. Use a 3/8-1/2 adapter and a nice long breaker bar. If they are truly stuck, don't keep tugging or pushing on the breaker bar or they'll strip, or you'll break the bit. Use a rubber mallet to strike the breaker, or an impact wrench to shock the bolts loose.
Old Mar 17, 2020 | 06:51 AM
Engine: 4.7 Liter
T45 is really sloppy in the bolt, that's why I'm thinking it's a T47. I can get one through Amazon, but that has to wait for next paycheck. We'll find out when I get it.
Old Mar 17, 2020 | 01:41 PM
chrias's Avatar
Rent the torx bit set
Old Mar 19, 2020 | 06:21 PM
Engine: 4.7 Liter
Actually, my answer was factual. Not rude, condescending, abrupt, hurtful, terse, mean spirited, angry, snobby or snobbish, arrogant or conceded. How everyone reads it, is how they look at responses. If they think that I wrote it that way, then they clearly must think that everyone talks that way to them.
Old Mar 19, 2020 | 06:30 PM
Drew's Avatar
Terse - adj. Brief and to the point; effectively concise.
I didn't get the impression anyone one took offense.
Old Mar 30, 2020 | 08:12 AM
thainglo's Avatar
I just pulled a complete TPI setup from my 88 parts car. Intake to head bolts were T45. Definitely on tight. I used an electric impact gun and had no trouble spinning them off. A few bolts needed the crud picked out of them to fully seat the bit.
Good luck!
95firehawk383
Nov 23, 2014 08:32 PM
ak1059
Oct 4, 2008 07:08 AM
stingerssx
Nov 8, 2004 09:19 AM
thunderstick
Oct 9, 2004 10:18 AM
Gary
Feb 5, 2002 08:33 AM
