Intake manifold bolts
Can someone tell me on an 89 firebird 305 tbi automatic car what the intake manifold bolts would be? I've heard torx but mine are normal bolts. I'm wondering which cause I wanna know if mine has been messed with and changed out, but it looks totally stock and evenly as dirty as the rest of the engine.
Re: Intake manifold bolts
I care, hence the reason I asked and I stated why I'm asking. If they are SUPPOSED to be torx and are not then that means she's been apart and the owner lied to me. Otherwise I understand what you are saying but it's still a valid question.
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Intake manifold bolts should a combination of standard SAE grade bolts and studs. Size 3/8"-16 x 1-1/4" Head size is 9/16" (or 12 point 14mm will work in pinch). OE GM bolts have a circle on its head surface.
//RF
Thank you. Exactly what I have and engine has definitely never been apart....until now. GUNKED UP!
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
