High idle 91 GTA
Old Apr 25, 2020 | 02:41 PM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
High idle 91 GTA
my 91 GTA 5.0 Tpi and she idles really really high.. at almost and sometimes over 1000 Rpm, the temperature hand is always on cold.. thoughts? .. cooling sensor was changed... should i change the sender?
Old Apr 25, 2020 | 05:12 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: High idle 91 GTA
Vacuum leaks ?
Old Apr 25, 2020 | 06:05 PM
Engine: V8 305
Vacuum leaks ?
not that i know of i will get her a new IAC valve
Old May 1, 2020 | 01:54 AM
90_WS6_Formula's Avatar
Car: 91 Z28
I'd try cleaning the one you have first. While you ere at it check the condition of the connector as well.
I'm currently having the same issue. Mine idles around 1500. I've checked all the vacuum lines and even took apart, cleaned, and reassembled the TPI intake. It's better now but not where it should be. ..
goalieforlife
Exterior Parts for Sale
May 30, 2016 02:33 PM
3.8TransAM
Members Firebirds
Nov 8, 2007 12:49 PM
