Suggestions please
Old Apr 29, 2020 | 06:38 PM
Suprared89's Avatar
Car: 1991 Z28
Suggestions please
Team Third Gen,
I would like some opinions/thoughts/experiences please.
My 1991 Z28 carries a 350 bored 30 over with a procharger. Still has pretty stock TPI set up. It also has some basic upgrades to accomodate the supercharger set up.
I purchased and EBL with the ecu and have had my fill with trying to get it dialed in. Not to speak ill of EBL. The depth of tuning is just well beyond my capabilities.
My question is about removing EBL and adding a self tuning system. I was advised to look into the Holley 560-601 system. It would be another 2-3k investment and i really would like to know what the team thinks. Would LOVE to hear from those that have tried it, and if there is another option..... please let me know.
Furthermore.....If anyone is upgrading and would consider selling a good COMPLETE system.... I may be interested. If you seek an EBL... Please let me know that too.
Thank you all!
Old Apr 29, 2020 | 07:27 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Suggestions please
Sounds like this should be posted in the dfi efi section.
Old Apr 30, 2020 | 05:32 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Not sure what depth you're referring to, as the system has all of the parameters already filled in. All you're doing is smoothing it out. Select your L98 bin, change your engine size to 355, select the size of your injectors, select which MAP sensor you are running, and that is it. Where is the depth? The boost parameters (fuel and timing) are already filled in for you. All you are doing is smoothing everything out, the VE, the SA, the AE,the PE, which again are already pre-filled from the L98 parameters. I would be glad to walk you through it...
... but if you have your heart set on the Holley, then go for it...
- Rob
Old Apr 30, 2020 | 09:08 AM
GeneralDisorder's Avatar
Self tuning EFI is a BAD idea for a forced induction application. It can't know what's appropriate for your combo. You should look for a proper tuning shop with dyno that is willing to dial in the EBL for you.
GD
paul nl
Aftermarket Product Review
Jun 14, 2009 02:23 PM
fcukit33
Alternative Port EFI Intakes
Apr 5, 2009 12:32 PM
rattlesnake_dm
Apr 18, 2006 09:22 PM
92camarors5spd
Jul 29, 2005 06:10 AM
BowtieNut
Aug 14, 2001 12:46 PM
