88 IROC stalling when put in drive
Car: 88 IROC Convertable
Engine: LB9 5.0 TPI
Transmission: 700R4 Automatic (MD8)
Axle/Gears: 3.73 posi
Need some help . I have an 88 IROC convertable with an LB9 engine and 700R4 transmission. Engine starts fine and will idle all day at 750 rpm. As soon as i put it in drive, the rpm drops and the car stalls. It will restart right away, but wont idle in gear. Any help with this problem would be greatly appreciated.
Rob C
Rob C
Re: 88 IROC stalling when put in drive
Check and clean the idle control valve, adjust the minimum idle air and TPS voltage.
GD
GD
Engine: LB9 5.0 TPI
Thanks GD, i'll check these units and revert back when i know more. Offshore now won't be home for a while.
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Car: check
Engine: check
Transmission: check
Also, check the P/N input to the ECM. It uses it to help prevent stalling and idle speed. Easiest is to use a scan tool. But a DVM can also be used. This switch is on the shifter assembly.
RBob.
RBob.
