Replaced fuel regulator
Old Jul 25, 2020 | 02:41 PM
Ironmike77's Avatar
Ok guys so I had a big issue today while replacing my regulator. When I took it off, fuel just kept pouring out of the fuel rail, where the regulator sits. And it would not stop, I had to hurry up and put the new one on. It literally kept leaking. Not even leaking, it kept pouring out. My intake was also filled with gasoline when I took it off to replace the regulator. Any ideas of what this could be. And yes I had the battery disconnected, so there was no power to the fuel pump or injectors.
Old Jul 25, 2020 | 03:00 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Replaced fuel regulator
Did you open the gas cap to let the pressure out?
Old Jul 25, 2020 | 03:04 PM
Ironmike77's Avatar
Man I feel like an idiot dude. I did not! It didn’t even occur to me until you just mentioned it!
Old Jul 25, 2020 | 03:05 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
A little pressure is all it takes to keep is flowing.
Old Jul 25, 2020 | 03:07 PM
Ironmike77's Avatar
And it’s funny you mention it. Because I went to go get gas. And you could hear all the air hissing out as I removed the cap. And this is why I’m glad we have this site. Very informative, even with minor details.
Old Jul 25, 2020 | 03:26 PM
GeneralDisorder's Avatar
Simply crimping the supply and return hoses would have stopped it even if it was siphoning. Vice grips and a couple of nickles will work in a pinch. Removing the fuel cap is also obviously useful to reduce pressure in the tank.
GD
Old Jul 25, 2020 | 03:29 PM
Ironmike77's Avatar
Yeah that’s my fault. Should have read up some more about replacing it. Will a bad regulator cause fuel to go into the crankcase? Or just into the intake?
88astrotpi
Feb 9, 2016 04:50 PM
dennisbernal91z
Jan 30, 2006 05:55 AM
acidpad
Oct 24, 2004 10:54 AM
Rob P
Oct 21, 2000 08:22 AM
