putting back factory throttle body for better MPG?
Old Oct 7, 2020 | 06:14 PM
msammy93's Avatar
Car: 1988 Trans Am GTA
Engine: 383 TPI
Transmission: 700r4 3000 stall non-lockup
Axle/Gears: 12 Bolt Rear 3.73
If I have a 10.25:1 383 stroker, could I put back the factory throttle body and smaller injectors to get better MPG? I know I'll be cutting my power in half, but I really only cruise the car. Just wondering if reducing air and fuel would cause running issues or detonation issues.
Old Oct 7, 2020 | 07:48 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: putting back factory throttle body for better MPG?
Tpi ? Stock 48mm throttle body won’t effect fuel economy. You can see air fuel ratio with a wideband.
dont want to lean out to much. If tune is safe make sure hwy mode is enabled.
Old Oct 7, 2020 | 10:33 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
One thing that I see is that you are running a 700R4 non lockup. Running a non lockup torque converter will cause reduced gas mileage. I agree with Tuned that you should look at running a wide band O2 and see your A/F ratio. Also read your spark plugs to see if the motor is running rich or lean. Good Luck.
Old Oct 7, 2020 | 10:47 PM
msammy93's Avatar
Engine: 383 TPI
If I wanted a transmission shop to install a lock up converter, would I just need to buy a lock up converter, or are there electronics and stuff that are also needed?
This isn't the factory 700r4, it's a art carr unit.
Tootie Pang
Nov 20, 2023 03:54 PM
LB9GTA
Aftermarket Product Review
Jul 30, 2007 08:17 AM
V8 Slayer
Mar 11, 2005 11:06 PM
AM91Camaro_RS
Apr 10, 2003 10:09 AM
