View Poll Results: Trying to figure out what goes there
Is it a sensor
0%
Is it for the egr
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Mystery part
Old Mar 2, 2021 | 07:26 AM
KoltinC's Avatar
Mystery part
Trying to figure out what it is that could go into that hole there in the intake on the driver side of the engine where the plenum connects to the intake at the bottom
File Type: mov
Old Mar 2, 2021 | 07:38 AM
Reddragon88gta's Avatar
Engine: 5.7 L98
Re: Mystery part
Cold start injector is missing...not necessarily a bad thing as long as you get the block off kit and get a new chip with the 89' start up code. Also make sure the fuel rail end of the cold start injector is plugged too. If you want a CSI I have one from my car that was in working condition when removed last year. What year is your car?
Old Mar 2, 2021 | 07:50 AM
KoltinC's Avatar
Re: Mystery part
it’s an 85 z28 engine that I’m putting into my 91 RS
Old Mar 2, 2021 | 08:46 AM
Engine: 5.7 L98
Re: Mystery part
I would just block it off then and get a chip burned with 89' cold start up. Are you running the ECM from the 85?
Old Mar 2, 2021 | 08:50 AM
KoltinC's Avatar
Re: Mystery part
yes I am how do you get a burned chip
Old Mar 2, 2021 | 09:10 AM
Engine: 5.7 L98
Re: Mystery part
https://tunedperformance.org/ and he is a member here with the handle Tuned Performance.
He can likely set you up with a PROM chip. I have a basic chip he set up with lower fan temp activation, 89' cold start up, VATS delete etc. that really helped my car perform better and run cooler.
Ebay also has a few of those 9th injector block off kits too for under $20.
Old Mar 2, 2021 | 09:11 AM
KoltinC's Avatar
Re: Mystery part
yeah I already ordered one of them thank you so much for all the help
Old Mar 2, 2021 | 09:18 AM
Engine: 5.7 L98
Re: Mystery part
Glad to help, good luck with your swap.
86camaroZ
Oct 25, 2020 08:31 PM
Arctic White 91 RS
Aftermarket Product Review
Feb 28, 2017 06:35 AM
nelapse
Mar 5, 2007 09:00 AM
