Idle issues
Old Mar 2, 2021 | 10:12 AM
Thomas Mcquirt's Avatar
Car: 1992 Chevrolet Camaro RS
Idle issues
My 1992 Chevrolet Camaro RS 5.0L is having issues with idle. I replaced the rotor button cap plugs and wires. Also had to recently replace the battery bolt because it was stripped. I haven’t had the car long and trying to find out why it’s wanting to stall at idle but usually straightens back up. What could be causing this. I put in a carburetor and injector cleaner in the fuel last time I filled it up. And usually I run unleaded plus gas but I put regular unleaded in it by mistake last time. Could this be causing it to run like crap? What can I do to get it running better
Last edited by Thomas Mcquirt; Mar 2, 2021 at 01:55 PM. Reason: Some things misspelled
Old Apr 5, 2021 | 10:30 AM
tkingfire30's Avatar
Re: Idle issues
Mine was doing the same thing. Ended up being a wire was touching the fan blade when it would kick on. Simple fix. Hopefully yours is the same.
SkidogP
Nov 17, 2020 07:52 AM
DaScorpio96
Apr 16, 2020 02:29 PM
Chakadog
Carburetors
Nov 7, 2019 03:33 PM
AlkyIROC
Sep 22, 2009 06:32 PM
