32-36lb Fuel Injectors
Old Apr 26, 2021 | 01:04 PM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
I am abnout to order some new injectors. I had purchased a set of 24# Bosch injectors off a friend, but I don't think they will be enough. Long story short, running a Vortech with FMU, now that I am running EBL and dialed the tune in (except for maxing the injectors out) I want to put the proper size pump and injector in and go away from the FMU.
The range is due to what base fuel pressure I run at, but I am more worried about what is available with:
1. Good reputation ( I have heard Accel is crap, but never used them)
2. Voltage offset data is available for.
What fills the bill? Unfortunately retailers don't always tell you if the injector data is available.
dustpusher
Feb 19, 2008 11:01 AM
1992rs/ss
Jun 2, 2005 01:34 PM
Duke901
May 23, 2003 09:48 PM
RU-QWIK
Mar 29, 2003 01:43 AM
Steve10
Jan 10, 2002 02:44 PM
