Heads, Casting number 624
Old Jan 17, 2002 | 05:37 PM
johndo1707's Avatar
hi, i am looking into some heads and was wondering exactly what they are. i was told they are 76 cc and were vette heads. the casting number is 624. can anyone veryify what these are? thanks a lot!
Old Jan 20, 2002 | 09:00 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Heads
They are not 'vette heads. They are 76 cc 1.94-1.50 perimeter bolt pattern on the valve covers and are for early style intakes(up to '86). They would lower the compression too much unless you change pistons.
Old Jan 21, 2002 | 11:52 AM
johndo1707's Avatar
yeah i will be changing pistons. i am building a 355 tpi motor from scratch and havent purchased anything yet. i am getting all my parts straight before i do anything yet. i have one more question for you. what compression ratio should i be running with a set of domed pistons? tahnks a lot
Old Jan 21, 2002 | 07:10 PM
Dyno Don's Avatar
Heads
No more than 9.8 with steel heads, alum. maybe 10.1
Old Jan 21, 2002 | 11:54 PM
johndo1707's Avatar
yeah, i'm going with forged aluminum speed pro. should be good. thanks a lot
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
camaro71633
Sep 1, 2015 10:24 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
dcbsracing007
Aug 18, 2015 07:24 AM
