Inline fuel pump question
Did you leave your stock pump in place and just unplug it or did you remove it and run a pickup tube to the bottom? I'm thinking of running an inline for later when I do my 383 build and am curious. Thanks
from what I understand you just put the new pump inline, kinda like supplemental to the stock one, maybe I am dead wrong, but I dunno, I am kinda wonderin the same thing, cuz I wanna do it to mine.
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
has anyone done this??
cmon I know someone has done this with the stock pump still in place. I would like to know what brand of inline pump you used and how easy it was to install into the existing fuel system and wire up.
THANKS FOR ANY REPLYS!
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
I used a Vortec 50/70 inline pump on my 89 IROC when I added the twin turbos. I use a Vortec FMU to raise the fuel pressure under boost- FP at maximum boost is 85psi (I needed high fuel pressure for the enrichment as I am running stock ECM). I plumbed the vortec pump between the stock in-tank unit and the fuel filter. Wired the inline pump to come on whenever the stock pump is running (power goes thru a relay of course). Works very well for me, except for the noise of the vortec unit. I have added extra insulation and rubber mounts, but that pump is Extremely loud (humms, moans, groans). May not bother some people though- remember with performance there is always a trade-off. I plan to install a 255lph in-tank pump in the near future, as I am un-happy with the noise.
Anyone want a good used T-Rex?
PS- 50/70 means 50gph@70psi
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
