tpi fuel line routing
Old May 3, 2022 | 07:21 PM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
my car came with tbi. im replacing that engine with a used first TPI unit. im thinking the fuel lines will come from the factory lines in the front to the pressure regulator that im going to mount on the passenger side of the TPI manifold near the runners. from the regulator i want to run the pressure line to the rear of the driver side fuel rail where the 9th injector would have been. from there the fuel will split between the two sides via the rear cross over hitting all injectors. then through the front crossover and out the passenger side front to the factory return line. my question is will having the pressure go into the rear of the driver side where the 9th injector would normally go be alright? i know normally the pressure splits at the regulator and goes to each side from there. what say you all? i just want to make sure im not going to starve it for fuel by not sending pressure directly into each rail separately.
Evilokc
Dec 19, 2021 03:46 PM
Mike_in_Texas
Apr 1, 2019 09:00 PM
GTA1990
Alternative Port EFI Intakes
Jan 6, 2019 01:48 PM
whitecamrs
Nov 25, 2004 09:36 AM
1987gta
May 22, 2002 12:14 AM
