Staring Hard after Injector Change
Old May 17, 2022 | 11:43 AM
cwb90's Avatar
So I just changed out my injectors because of hard starting after the car was hot or driven. After the injector change the car now starts hard and stumbles off idle when cold but starts fine when hot. I have a 88 5.7 TPI. Fuel pump was changed last year. I changed the fuel regulator diaphragm along with the injectors. I used 22# Delphi injectors. I also checked for vacuum leaks. Any ideas?
Old May 17, 2022 | 08:49 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: Staring Hard after Injector Change
I'd look into the cold start injector for proper operation. And check that the fuel pump is running for a few seconds when the key is first turned on.
2012sergen11
Jun 15, 2013 03:55 PM
hornick
Oct 4, 2011 02:47 PM
wanab03ss
Nov 13, 2007 01:19 PM
rumpilstiltskin
Mar 13, 2003 10:53 PM
mmcdjs
Sep 27, 2002 03:15 AM
