Blinging up the TPI
Old Jul 19, 2022 | 11:11 AM
jimxms's Avatar
Blinging up the TPI
Coming from my previous bird which was a very simple carb setup and chrome everything, the TPI engine bay looks a right mess. What can be done to clean it up and bling it out a bit? Are there any emissions parts that can be removed without causing running issues? Does anyone on here have pictures of a cleaned up TPI setup? TIA
Old Jul 22, 2022 | 11:35 AM
SixSeriesCSi's Avatar
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
Re: Blinging up the TPI
Bling Bling!!
Tuned Port Injection-Polished - Third Generation F-Body Message Boards
Old Jul 22, 2022 | 12:19 PM
wlink14's Avatar
Car: '87 TA
Engine: 6.0LS
Transmission: 4L80e, 3000 stall
Axle/Gears: DIY 9 inch, 3.00 gear
Some things that cleaned up my engine bay a lot were removing the windshield washer tank and pump, and painting my old, yellow-stained coolant reservoir. A good cleaning goes a long way too!
Old Jul 22, 2022 | 04:28 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
I think the duplicolor metalcast base coat / dyed clearcoat comes out nice if you are careful. It holds up to heat well but being rattle can it scratches easy. That's what I did on mine you can look up here.
lxcamaroxl
May 19, 2005 01:52 PM
Stang_Killa
May 21, 2003 06:07 PM
T/A_SXracer
Jan 17, 2003 08:33 PM
TPI400guy
Jan 26, 2001 10:11 PM
