Fuel return line
Old Oct 24, 2022 | 10:06 AM
sixty3's Avatar
Fuel return line
You guys have been a lot of help, I’ve tried to read a lot as I’m trying to rehab this 1987 IROC.
I pulled the rails and injectors, car had been sitting for a long time, 6 of 8 injectors were junk and have some new injectors coming from southbay. As I was taking the fuel rails off I broke the return line that goes to the rubber hose from the “block” on the injector rail. If I even look at a line in this car……it falls apart, good times.
I’ve used some google but can’t find the line to purchase, any help?
Old Oct 24, 2022 | 10:18 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel return line
Is it the crossover rubber line that broke ?
Old Oct 24, 2022 | 10:24 AM
sixty3's Avatar
The metal line before it gets to the rubber hose broke. I needed to unscrew the line from the fuel rail “block” and it was just rusted together and I broke that line trying to get it off.
Old Oct 24, 2022 | 10:29 AM
Engine: Lb9
Transmission: M20
@John in RI might have these I only have a few sets of 88-92 serpentine belt hard lines. Or post in the wanted section for 85-87 tpi v8 hardlines. Not sure what your referring to the hardline on tpi does not screw in to the regulator body . Just a o-ring and retainer .
Old Oct 24, 2022 | 10:42 AM
Engine: Lb9
Transmission: M20
This person has the rail to crossover lines
https://www.facebook.com/marketplace/item/648360030005664/
if your line is broke at regulator can usually find 85-88 fuel rails on eBay
Shakenblake
Aug 3, 2017 09:02 PM
liveyourself
Sep 28, 2008 09:29 PM
graebz28
Aug 26, 2008 05:41 PM
kickasscamaro
Jan 4, 2006 03:44 PM
Marshall89ws6
Apr 2, 2002 08:47 PM
