Installing Aeromotive 13301 VAFPR
Old Aug 26, 2008 | 03:32 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
I see that everybody installs the line downstream of the TB on the return line. Could it or would it be better to block off the return and run it this way:
Hardline Fuel Supply to Inlet on VAFPR
Harline Fuel Return to Return on VAFPR
VAFPR Outlet to TB inlet
Block off TB return line
Old Aug 26, 2008 | 03:55 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Installing Aeromotive 13301 VAFPR
No.
It needs to be on the return line downstream of the TBI unit. Otherwise the only way to purge air & vapors is out the injectors.
RBob.
Old Aug 26, 2008 | 05:41 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Thanks Rob. Makes perfect sense.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
deracer
Apr 11, 2016 12:04 AM
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
