TPI tune up
Old Oct 27, 2022 | 08:49 AM
1965gp's Avatar
TPI tune up
About to pick up my new to me 87 Formula 350 from the body shop.
I want to do a good tune up but have been out of the third Gen game for a while. Any specific plugs, coil, wires, etc that I should use?
25 years ago it was Taylor wires and an Accel super coil but I’m sure there is something better out there.
Old Oct 27, 2022 | 08:25 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Re: TPI tune up
Stick to AC Delco for the coil, the aftermarket “high performance” stuff seems to crap out fast compared to the Delco stuff and unless your running a real hot set up not worth it. Same for the wires but if you want bigger than 7mm Taylor or DUI make good stuff but if just a cruiser AC Delco would fit the bill. Plugs…everyone has an opinion on them and I myself run AC Delco Rapidfire platinum and have no complaints but honestly if I was to do it again would use the standard copper AC Delcos and call it a day and save some $. If you ever need an ignition control module definitely stick with OE or Delco, the other brands really don’t last from what I’ve read on here.
Old Oct 27, 2022 | 08:31 PM
ULTM8Z's Avatar
Re: TPI tune up
Actually Pertronix stuff is really good. Their module and coil as a combination is very potent and reliable (I've had them for a couple of years now).
but you will notice a difference in driveability and throttle response over a stock module and coil. I used to think the high performance modules were gimmicks until I tried theirs.
Old Oct 27, 2022 | 09:43 PM
1965gp's Avatar
Re: TPI tune up
Thanks guys- this is a pretty stock car so this points me in the right direction. Supposed to pick it up tomorrow from the paint shop. Would like to get the tune up parts on order soon.
Old Oct 27, 2022 | 10:09 PM
Engine: 5.7 L98
Re: TPI tune up
That is good to know Petronix is making quality stuff, I’ve heard a lot of bad stuff on here about Accel modules and MSD ignition parts failing very early.
Old Oct 27, 2022 | 10:13 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: TPI tune up
I pulled the distributor out of mine a couple years ago and was kind of shocked at how nasty it was inside. Might take a close look inside yours, parts are not real expensive and might save problems down the road. Also removed one screen in the MAF and gave it a good cleaning.
Old Oct 28, 2022 | 11:34 AM
ULTM8Z's Avatar
Re: TPI tune up
Yeah I tried the Accel one years ago and it was failed right out of the box. Total POS.
Havent run MSD so cant speak to that.
Old Oct 28, 2022 | 11:44 AM
ULTM8Z's Avatar
Re: TPI tune up
Old Oct 29, 2022 | 07:08 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: TPI tune up
I use the MSD, the Blaster coil, the stock replacement style. I have had it in the car for over 5 years and no problems. I also use their Supper Conductor 8 mm wires, MSD rotor and cap and the AC Delco Rapid Fire plugs. I used a Jegs hi RPM ICM and it failed within 2 years or less. I replaced it with the A/C Delco and has been good since,
For your application The stock A/C Delco replacements will be just fine. I was doing a engine detail with red as my primary color so I chose MSD for that reason but I am happy with their stuff.
onefreakz
Apr 9, 2019 06:20 PM
camaro87jb
Aug 5, 2010 10:27 PM
84camz28
Mar 28, 2007 07:11 PM
Slow2.8
Feb 18, 2003 04:41 AM
86camarodriver
Sep 4, 2002 02:46 PM
