TPS interchangeability
Car: 1955 Chevy Belair
Engine: 87 L98 from Corvette converted SD
Axle/Gears: 3.08 POSI
Thanks for accepting me.
Can I put a 87 TPS on a 92 L98? I need to adjust it. The lowest voltage I can get is.72.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPS interchangeability
Yes you can, .72 will work. Was iac adjusted before tps ?
It was when I first put the car together (2004), but I haven't done anything to it since.
The problem with adjusting an IAC is that as soon as it is plugged in, the ECM will "adjust" it to whatever it wants. Adjusting throttle minimum position is another matter altogether. We knew what you meant.
TP is correct that with the 1227730 ECM anything between 0.24 and 0.94V is suitable since the ECM will assume the "zero" position upon ignition power-up.
