Fuel pressure regulator.
I recently put new heads and cam in my tpi 305, my vacuum is lower due to cam, I think it’s affecting my fuel pressure regulator but letting too much fuel in engine, will an adjustable fuel pressure regulator help this issue if I dial it back? Or is there a different method I can use
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel pressure regulator.
You can tune it, check out the diy prom
Section.
AFPR will not go lower than 3 bar
Section.
Car: 1989 IROC-Z
Engine: L98 350 TPI
What is your fuel pressure right now? I suggest watching FiTech tutorial videos on YouTube for instructions on how to datalog and tune your system. There are also a few manuals on the handheld tuner to help with adjusting fueling parameters.
