Hard gas pedal
Car: 1991 RS
Engine: L03 305
Hard gas pedal
I have a 92 Camaro with the 305 TPI. The throttle has a hard spot right at the top where you have to push it hard. Past that, the petal is smooth as silk. How would I fix this?
Car: 1989 Firebird
Engine: 2.8 Liter V-6
Re: Hard gas petal
does the pedal feel sloppy side to side? Possible that the bushing at the pivot point has degraded and is binding. It’s a cheap part and not a terribly difficult repair it that’s the issue.
Car: 1991 RS
Engine: L03 305
Re: Hard gas petal
doesn’t seem to have in play to the sides. I’ve tried lubing the spring in the throttle body and the assembly but I’ve had no luck. Do I maybe need to just grease the throttle cable?
Novacain77
Oct 17, 2009 10:10 PM
nesluopetan
Mar 4, 2002 01:10 AM
