I am wondering what other inputs if any influence the "air flow" data?
At first glance airflow just looks like a duplicate of MAF data , but I am realizing they are different.
Are both of these coming solely from output from the MAF sensor? Or is it a combination of info on the airflow reading?
Is this the dynamic calculation from the ECU's learned A/F tables?
Assuming you have a '7165 with $6E mask, TPI system
The MAF sends a voltage to the ECM B12 (0-5volts). The ECM looks-up the voltage in a series of MAF tables. The g/sec returned data was human programed by GM. The g/sec data is used by the ecm to calculate injector base pulse width (INJ BPW) before correction and other adjustments.
RPM is read by ECM from distributor
AFR is programmed data, usually 14.73 in closed loop
INJ Flow Rate is programmed data, usually 22.36 (for 5.7TPI L98)
The ECM has a provisions to return g/sec data in case of MAF failure. Unplug the MAF and try scanning. You should still see g/sec but will get a SES code.
I would not know why your scanner returns 2 sets of data for airflow.
