Missing Horsepower?
Old Sep 2, 2023 | 09:24 PM
TheMagikMan's Avatar
Car: 1986 Firebird Trans Am WS6
Engine: Cammed 358 TPI
Transmission: Built 700r4
Axle/Gears: 2.77 Borg-Warner 9 Bolt
Missing Horsepower?
Nothing is making sense. My tune is pretty good, and my MAF readings and injector utilization are consistent with making around 270 crank horsepower. With a double hump head, 10:1 compression, SLP shorty headers and matching y-pipe, 3" exhaust all the way back, and 3" intake tubing I should be making like 330hp at a minimum. MAF reads 204.44 g/s at 4725rpm as a maximum and my 24lb injectors are at 70% max PW (Both consistent with 270-280hp after some math). It seems like there's a flow issue somewhere and I can't for the life of me figure out where. This is incredibly frustrating. Any idea where I should look for missing power? The BLMs are pretty stable after a few iterations and I'm getting minimal knock. But this is driving me NUTS. I have a hyd. roller COMP XR269HR grind, mildly ported and 2.02/1.6 valve heads off a 69 Z/28. Everything on this motor should be supportive of 350-400hp and yet, it doesn't feel or appear even close to those numbers. Any place I should start looking? I don't seem to have a vacuum leak or anything either. From the research I've done, this 358 small block should be a little monster. Stock 86 TPI does match the cfm of the cylinder head intake runners after finding online sources for both (202cfm as-cast for the heads, 198-202cfm bone stock on the runners). This is driving me crazy!
Edit: links for similar spec cam dyno sheets (engine specs included) are below. My cam part number is 8-502-8
https://www.compcams.com/xr270hr
https://www.compcams.com/xr264hr
Old Sep 2, 2023 | 09:51 PM
ULTM8Z's Avatar
Re: Missing Horsepower?
Do you have a WB O2 to verify your AFR?
Old Sep 2, 2023 | 09:56 PM
I do not, however you can roughly tell by where the NB voltage sits, and I'm at about 880-890mV so it's right around 12.4:1
Old Sep 7, 2023 | 07:53 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Is this stock TPI? Those other parts might be able to hit 330hp, but not at the rpm the TPI wants to flow at.
Old Sep 8, 2023 | 11:24 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Is this a Camaro or Firebird?
Old Sep 9, 2023 | 01:16 PM
ULTM8Z's Avatar
Not sure you can make that assumption. From what I understand, NB voltage is not an indicator of a particular AFR.
Old Sep 9, 2023 | 01:18 PM
ULTM8Z's Avatar
BTW, 10:1 compression with iron heads and a cam with only about 218°@.050? What octane fuel are you running?
Wonder if the ECM is pulling timing out due to knock. That'll definitely kill power.
Old Sep 11, 2023 | 11:46 AM
BadSS's Avatar
If you're estimating 270 rear wheel by your extrapolations through an automatic, with drive accessories, and exhaust, then that converts to approximately 338 fly wheel HP which is what those other graphs you link were. Sounds like your not far off the mark to me. In fact pretty good with those heads and if the TPI is stock.
Old Sep 11, 2023 | 03:38 PM
It's a Firebird. 1986 Trans Am to be exact.
Old Sep 11, 2023 | 03:39 PM
I run 93 octane. Viewing my datalogs, the ECM only detects knock on downshift when the RPM spikes, which is likely false knock, but I can't get it to stop applying knock retard no matter what I do to disable it in the BIN.
Old Sep 11, 2023 | 03:41 PM
I'm estimating 270 at the crank, although it's unclear if my estimation tools use crank horsepower or wheel horsepower. I need to get it on a chassis dyno at some point to look and see exactly where it's at.
Old Sep 11, 2023 | 04:12 PM
ULTM8Z's Avatar
how much retard is happening? Real knock or not, if the ECM is pulling timing, you'll lose power.
Old Sep 12, 2023 | 06:50 AM
3.5 degrees at most under WOT, and it all recovers before I get into the next gear.
Old Sep 17, 2023 | 02:03 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I 2nd his comment. I absolutely can determine WOT AFR from a GM Narrowband.
890mv NB also corresponds to ~12.3 on my AEM Wideband.
930mv = 12:1
880mv = 12.5:1
830mv = 13:1
450mv = 14.7:1
100mv = 15.5:1
30mv = 16.5:1
Old Sep 17, 2023 | 02:41 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
If it still has the stock air filter and ducting that could definitely be your choke point. SLP had to redesign the air intake ducting and filter setup on the Firehawks.
Old Sep 17, 2023 | 11:11 PM
It does not have the stock air filter, it has one of those ebay 3 inch intakes with a pod filter on it, which is bad for MATs but flows way more than the stock airbox.
Johnny Blaze
Jul 8, 2013 01:48 AM
cooljo39
Mar 18, 2011 12:46 PM
FireDemonSiC
Sep 4, 2008 05:21 PM
Raiden
Dec 9, 2003 10:14 PM
Paul Riccioli Jr
Jan 30, 2003 10:59 PM
