91 tpi O2 issue
Old Nov 27, 2023 | 07:23 AM
Faolan's Avatar
91 tpi O2 issue
Car runs good and has great power, new O2 plugs wire cap dostributor and new intake gaskets.
issue is when it hits closed loop it's apparently running extremely rich so it pulls fuel and starts missing sometimes lean surge etc. still runs great when I'm actually driving thought. at idle and very low rpm cruise I'm seeing 108 blm and 97-116 int while occasionally missing
no codes,
unplugged O2 no problems no codes. should set a code correct? Bad ecm maybe? Just looking for suggestions before I buy injectors (pretty sure they're original) all sensor values seem in spec and okay from what I've gathered.
Old Nov 27, 2023 | 07:35 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: 91 tpi O2 issue
If you think your injectors are original dig into that to verify. If so, almost certainly bad. I went with Southbay and am very happy with them.
Old Nov 27, 2023 | 08:32 AM
Faolan's Avatar
Re: 91 tpi O2 issue
How do I check if they're original? I'll post a pic of them after work. They're grey if that matters
Old Nov 27, 2023 | 12:07 PM
southbay08's Avatar
Re: 91 tpi O2 issue
either send a pic or give me the part number off of the injector. I'll let you know if they are stock
Old Nov 27, 2023 | 12:14 PM
Faolan's Avatar
Re: 91 tpi O2 issue
didn't see the part number, here's a couple pics
Old Nov 27, 2023 | 12:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 91 tpi O2 issue
Definitely a problematic multec injectors
Old Nov 27, 2023 | 12:57 PM
Faolan's Avatar
Re: 91 tpi O2 issue
Thanks for the confirmation, I'll get a set ordered and see how it goes
Old Nov 27, 2023 | 03:58 PM
southbay08's Avatar
Re: 91 tpi O2 issue
Yup...those are the originals....as tuned performance mentioned...extremely problematic!!!
Old Nov 27, 2023 | 07:03 PM
Vader's Avatar
Re: 91 tpi O2 issue
Most of those Multecs did their job successfully - They lasted through the warranty period. The prior version RP/Bosch injectors seemed to be a lot more reliable in the long term.
Old Nov 28, 2023 | 02:11 PM
MikeKy's Avatar
Car: 1955 Chevy Belair
Engine: 87 L98 from Corvette converted SD
Axle/Gears: 3.08 POSI
Re: 91 tpi O2 issue
Just put Southby in mine and they are great.
Old Dec 2, 2023 | 03:51 PM
Faolan's Avatar
Re: 91 tpi O2 issue
Thanks South Bay, had 3 bad on drivers side according to the ohms, car runs good at idle and great everywhere else WITH the o2 unplugged. Still get the same symptoms as before when it's plugged in. This is anew sensor
can anyone link me the best single wire o2 for this car? Thanks in advance
Old Dec 3, 2023 | 07:28 AM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: 91 tpi O2 issue
I think anyone who still have those should just change them no matter what lol
I'm guilty of it. Have an '89 IROC-Z all original low milage with them on. Runs great! I also have a new set for it but too lazy to swap them, waiting for them to fail I guess.
m300slr
Jan 2, 2023 01:14 PM
liquidh8
20
Apr 22, 2007 10:26 PM
trigger GTA
May 21, 2003 04:20 AM
gta324
Nov 21, 2002 09:33 PM
2QUIK6
Sep 26, 2002 09:55 PM
