91 TPI 5 speed into 87 ex-carb
Old Jan 5, 2024 | 05:24 PM
RobC87's Avatar
Car: 87 IROC & 91 Z28
Engine: Working on it
Transmission: Working on it
I bought a 91 305 with a 5 speed, after getting it home I cam to the hard decision to part it out. The car is twisted from a accident, and is not worth fixing. Basically I got screwed on it, and it is not worth fixing. So my solution is to buy a 87 IROC with no power train (had a carburetor engine) and I am planning on moving the running gear from the 91 to the 87.
I have a few concerns on this, and would appreciate some advise.
  1. The 87 was a automatic with a mechanical speedo, the 91 is a 5 speed manual with a electronic speedo
    1. How do I convert the mechanical to electronic speedo, I want to keep the 87 cluster as I like them over the 90-92 clusters.
  2. Since the 87 was not TPI and I plan on installing the TPI into it, I will need to move the ECM and wiring harness too, can the 91 harness be split apart
    1. Can this be done, or should I try to find a 87 harness from a TPI car?
    2. I have the gas tank and sending unit out of the 91, will the 87 even have power at the tank to run the fuel pump?
The 91 is a complete running car with nothing missing, so I am trying to salvage as may part as I can.
SpeedFreakGT
Convertibles
Nov 1, 2021 04:44 PM
Stonehenge
Apr 13, 2011 05:06 AM
xplane
Nov 29, 2005 09:00 PM
ConvertRS91
Feb 7, 2005 04:24 PM
new87
May 9, 2001 08:01 AM
