TPI swap advice
Old May 15, 2024 | 06:42 PM
BillComm's Avatar
TPI swap advice
Hey fellas! What are the chances that a stock tpi intake setup will run properly on my 355 sbc with a 280h comp cam, 60cc trick flow heads controlled by a holley efi harness/ecu?
I have a really clean setup sitting on my shelf for a decade....I love the look but have been told to stay carb'd. Just a weekend warrior car, no track or strip.... looking to do something different this year.
Opinions?
Old May 15, 2024 | 07:19 PM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: TPI swap advice
You'll choke it!
Old May 15, 2024 | 07:37 PM
BillComm's Avatar
Re: TPI swap advice
Originally Posted by SbFormula
You'll choke it!
That's the exact same thing I've heard, and the main reason it sits on my shelf.
No amount of porting would help?
I could always get bigger runners, base plenum...but im trying to use what I have.
Old May 15, 2024 | 07:46 PM
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: TPI swap advice
This topic has been beaten to death. Do some basic reading and you'll get the idea.
TPI intake will reduce potential max HP by around 8% to 18%. The OEM TPI will be close to 18%. A high performance TPI like ASM will be more like 8%. It will move the torque curve down low and increase max torque though. So if your 355 is capable of, let's say, 350hp, a stock TPI intake will probably bring it down to 285hp.
Here's a good summary:
Old May 15, 2024 | 08:34 PM
BillComm's Avatar
Re: TPI swap advice
https://youtu.be/B3Je1MLTphs
Thanks for the help....on the shelf it stays then.
1bad88droptop
Jun 22, 2005 11:06 AM
bad_azz91
May 2, 2004 08:00 AM
Nonni
Feb 22, 2002 09:08 PM
