TPI swap
Old Apr 30, 2004 | 10:59 PM
bad_azz91's Avatar
Car: 1991 Camaro
Engine: 383
TPI swap
Ok so i got this TPI setup and it comes with basically everything except the wire harness. Now i dont know much anything about ecm's, and the different systems ive been reading about on here. What would i need to do to get this TPI setup to work on the 350 im building, considering i have the 305 TBI right now? Will the TBI harness work, or can it be repined maybe someone could explain that one to me cause im not sure what the exactly means either...Anything helpful would be nice.
Thanks alot
John
Old Apr 30, 2004 | 11:41 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The main page has a "TBI to TPI" swap.
Search function is also a valuable tool.
Old May 1, 2004 | 07:43 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
What year is your car and what year and car did you get the TPI set up off of?
Old May 2, 2004 | 08:00 AM
bad_azz91's Avatar
Car: 1991 Camaro
Engine: 383
My car is a 91, and the setup said it originally came off a mid 80s camaro when i purchased, but than the guy said he took it off a Small Block Grand National. The setup came with 30lb injectors.
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
