need cam help?
Old Apr 28, 2004 | 02:43 PM
Kandied91z's Avatar
need cam help?
what is too large of specs intake/exhaust with duration @ .050 to not have any vacum and cause problems with running issues?
Old Apr 28, 2004 | 06:15 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
If your running tpi and can't tune your own chip I would'nt go much bigger than 210 degrees on the intake side.
Old Apr 28, 2004 | 06:18 PM
Kandied91z's Avatar
i can't tune my chip....i know this however i'm learning. the problem is no one in the tri state area (certified shop wise) can tune the stock ecm and get it to start on its own.
it's programmed now to run and it runs decent but it will not start very well and when it does it spits up dixie cups of fuel.....if i don't play with the throttle til it warms up the car will foul the plugs.
i've called over 30 shops in michigan and outside and all of them have said we can do basic chip burns on mild stuff but anything with the type of engine i have will require an upgrade to fast or dfi setups.
i find this hard to believe when you have all the similar tools to use on a stock ecm for chip burning. if anyone can program me a chip that will just start my car with out any stupid tricks i will personally deliver them a very nice reward.
according to 50+ so called professionals it can't be done.
Old Apr 28, 2004 | 08:00 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
My cam @ .050 is 230/236, it's a Comp Cams hyd roller. This is on a 350 with a HSR intake. I don't remember the vacuum readings off my MAP sensor but it idles well enough to run my power brakes. Granted I'm using a Holley C950 ECU, so I have idle and part throttle dialed in.
FWIW, before I switched to the Holley C950, I had the MAF with a custom prom. Just for the hell of it I threw in the stock chip with my big cam and HSR and surprisingly it idled quite well on its own and ran decent.
That's why I find hard it to believe no one in your area can burn a correct prom for your car. If they say you need to switch to DFI then it's BS, they just want your money.
Old Apr 28, 2004 | 10:04 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
I'll definitely call BS to the them telling you have to swap to DFI. Give Ed wright a try at fastchip. He can get you alot closer than where you are. What is your motor and cam specs? My old file might help you out. But to answer your first question, I would keep it under 230 duration to play it safe.
Old Apr 29, 2004 | 02:02 AM
Kandied91z's Avatar
motor is a 388 with 58 tb and miniram III intake, all the belles and whistles on fastburn heads using 1.6 rr's with comp cam hydra roller that's 230/236 @ .050 with 111.0 lsa. the motor is 10.8 to 1 compression running 4" cai, 1 2/4" lt's with 4" exhaust. anything else?
anyone who thinks they can take a stab at even getting thing to start on its own without pedal tricks or either like the last guy told me to try will be worth their time.
if anyone is interested email me and i'll get a copy of the file to look at.
Old Apr 29, 2004 | 09:28 AM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
thats a very similar motor to what i have. I have a 388, AFR 195cc heads, Miniram, 222/230 cam. Is yours a Stick or Auto. My file is for a stick. I'm gonna have to dig it up. But mine should work as a start up file since its not that far apart from your motor.
Old Apr 29, 2004 | 10:37 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I have a bin file for a 91, 383, 11:1 afr heads, miniram, 236-242 cam that should get you close. Send me an email or a pm.
Old Apr 29, 2004 | 01:59 PM
Kandied91z's Avatar
sent both of you pms....i would really appreciate it very much as this is really giving me a hard time.
Old Apr 29, 2004 | 02:07 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Eli at car-pro in mt. clemens should be able to tune it, did you call them?
Old Apr 29, 2004 | 02:15 PM
Kandied91z's Avatar
they are no longer....haven't been for a little while. rumors of eli working out of someones garage yet everyone who claims this won't give me a number.
there isn't a phone book for disolved shops in the area unfortunately.
Old Apr 29, 2004 | 09:25 PM
Kandied91z's Avatar
well i can't get the .bin from the tuner.....if you guys can get me those files that i can look over though it would be great. i'm going to meet up with him over the weekend when i can get out of work and get that file myself out of his computer. i'll send it to all of you then.
just for the record he told me no one has ever tuned a large cam like mine in the car.......he would know, so how did you guys do it?
Old Apr 30, 2004 | 12:55 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
Did you get my bin file? Also Traxion or Mike Davis have tuned some pretty big cams using the factory 7730ECM. I believe Traxion's Lethal EFI Cam is probably equvailent to your cam right now and his motor was a 350.
Old Apr 30, 2004 | 07:56 PM
Kandied91z's Avatar
pm'd you!
Old Apr 30, 2004 | 10:17 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
cam specs
Hey Kandi did you get your problem fixed?
I was also wanting to know what size injectors you have??
I have a 383 with a crane 223/223 with 1.6's performer heads etc etc..I got my chip burned from a guy here in Houston...The chip runs in open loop and thats the only way that I get a decent idle... If I put the stock chip back in my car does exactly what yours does and just falls flat on its face (wont idle for ishhhhhhhhh)..
Old May 1, 2004 | 02:43 PM
Kandied91z's Avatar
nope, still working on it. trying to find a way to get my .bin file so that i can have others take a look. my tuner won't release it to me yet.....
as far as injectors i'm running 30lb svo's.
Old May 2, 2004 | 08:31 AM
robsgta's Avatar
cam help?
Hey kandi, The reason I asked was I had the orange 30 lb SVO injectors as well I installed them in my rails and gave them a try and my car ran like crap and ran extremely rich (dark black smoke at full throttle even half) my motor wouldnt idle for crap.. bought another set thinking it might be a few of them sticking open, then another guy in here told me the 30 lb injectors wont work well unless you have a dfi set up... I purchased 24's SVO's the blue ones and it runs strong idles good... Do you know if any one else in here is getting away with factory ecm and a chip upgrade with out any problems running 30 pounders.... My motor is very similiar to yours as well...
Old May 2, 2004 | 10:24 AM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
I had 30 lb injectors in my motor. Mine ran pretty good, with a extremely good idle at 750rpm. My motor just needed fine tuning on the dyno that i never got a chance to do before i put on the supercharger and DFI.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
