85 Camaro Runs with MAF sensor unplugged
Car: 1991 Trans Am GTA
Engine: 350 tpi
What’s up guys I have a 85 iroc z with a 305 tpi in it. With the maf plugged in it will not run it starts and dies and there is no ses light. With the maf sensor unplugged it will run fine just a little hiccup when you give it gas and the ses light is on. I bought a maf sensor from Delphi but when I plugged it in it did the same thing. I bought the AF10328 sensor. What is the next step to trouble shoot it I know these tpi’s are different from the other ones. Thanks in advance.
Engine: 350 tpi
Re: 85 Camaro Runs with MAF sensor unplugged
It was the original Bosh maf sensor. The one I bought was the delphi AF10328. I might change the plug maybe there is something wrong with it.
Engine: 350 tpi
Correct, so I’m thinking maybe the connector could be bad? Because as soon as I hook it up the car will start and instantly die. It will barely run. I’m probably going to return the Delphi one
Engine: 350 tpi
Well I think I fixed the problem. When I did the water pump I cleaned out the throttle body where the water runs thru it was plugged up with like calcium. I finished and plugged the maf sensor in expecting it to die and to my Suprised it ran and didn’t die anymore. It responded good when I accelerated it. I’m not completely sure how it fixed but it did and no ses light
My guess is Post #5, and your frequent disconnection and reconnection may have helped wiped the contacts clean. It may return, and you would have a better idea of what to check first. De-oxidizing contact cleaner can be very useful for both the contact surfaces and the crimped connections in these factory PED plugs.
trans_amforce
Jun 10, 2006 08:55 PM
