Ram air TPI on 1988 305
Old Jan 31, 2025 | 04:18 PM
FireballXL5's Avatar
Car: 1988 FORMULA
Transmission: 4spd auto
Axle/Gears: standard
I watched a video the other day that gave an easy way to add just a little more hp the base 305, by using a ram air system with shortened runners, then gave a co. the made these with complete kits, manifolds, runners, in throttle body, has anyone else heard of this low profile intakes. I have seen them but they seem to be only listed for the LS motors which I do not have, can i still incorparate this intake to my engine. I do know i would need to tweek computer or change it altogether.
Old Jan 31, 2025 | 04:24 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Ram air TPI on 1988 305
Gen 1 sbc and the LS platform are 2 entirely different things.
you need to search "free mods", tpis insider hints book and several other basics. That'll help pep it up before braking into the engine itself.
Old Jan 31, 2025 | 05:34 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
You are using some confusing terms and stuff in your question so I'm having to do a lot of mind reading and mental translating of what you said and what I think you meant to say.
Anyways I think this is what you are asking about. You need the Holley Hi-Ram Front-Feed EFI Intake Manifold Kit - Small Block Chevy PN 300-951 unless you have a big azz high rise hood. I'd do triple checks to see if the front feed version will fit under a 3rd gen Firebird hood and exactly which version of a 3rd gen Firebird hood.
Old Jan 31, 2025 | 06:08 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Or he's asking about a MiniRam.
Hard to say.
Old Jan 31, 2025 | 09:33 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
The pro Flo xt will fit and likely give a little improvement but you would need other mods to help w flow. It fits under a stock hood.
ksrammstein
Jan 8, 2004 01:35 AM
IROCZ88x
Feb 19, 2003 04:02 PM
E.T.
Jan 30, 2003 10:14 PM
blackztpi
Aftermarket Product Review
Jan 13, 2003 03:51 AM
