Need help
Old Nov 27, 2025 | 06:53 AM
Hojon's Avatar
Need help
I have an 89 Iroc with 5.0 and cant get it to start. It sat for a few years so I drained and replaced all fluids the dropped the tank, replaced it along with the fuel pump assembly and fuel filter. Replaced the fuel injectors, plugs, wires, maf sensor, throttle position sensor, egr valve, fuel pressure regulator, idle control valve. Still wouldnt start so I replaced the distributor (DUI) along with hotter coil. Re-gapped the plugs and new ECM. Still no luck. Fuel pressure is 40psi with key on and over 50 when trying to start. It turns over a couple of times and fires a little then just keeps cranking. If I keep cranking it just repeats. Ive pretty much replaced all electrical items and am out of ideas. Bought an inline spark tester to make sure its getting spark for my next check. Any other ideas?
Old Nov 27, 2025 | 07:56 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: Need help
Fuel, spark, and compression. Need all 3 functioning properly to keep a gas engine running. Start there with your troubleshooting. The parts cannon method is expensive.
Old Nov 27, 2025 | 09:42 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Re: Need help
So you say you got fuel and spark. Wild. Did you check timing after replacing the dist? verifying TDC on piston one matches rotor spark plug one? Did you try moving dist around a bit just in case it needs more advance/retard. Did you try some starter fluid to see if that makes a diff?
Old Nov 27, 2025 | 09:56 AM
Hojon's Avatar
Re: Need help
Set cylinder 1 to tdc on compression stroke and rotor pointing to #1 like the old one. Would think it would try and run even if timing is off by a little. Bought a spark checker and will arrive tomorrow. Want to double check spark at plug to verify. Starting fluid does the same thing. Fires a couple of times then keeps cranking even when still spraying starting fluid. Tried disconnecting the timing wire to see if that made a difference but it didnt. Wires connected correctly to each plug.
Old Nov 28, 2025 | 07:19 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Need help
If it won't run or otherwise backfire / make noise on starting fluid, you have no spark.
Old Dec 2, 2025 | 05:28 PM
Hojon's Avatar
Re: Need help
I received my inline spark checker and ive got spark. Sprayed starter fluid into it and it started and ran as long as I sprayed it at a high rpm. Died as soon as I quit. Going to get noid light back out and hook it up to the same cylinder as the spark checker and see how that goes. Timing is at 9-10 degrees BTDC. Making some progress, wouldnt do that until I changed the distributor.
Old Dec 3, 2025 | 10:49 AM
codyman125's Avatar
Car: 1989 Firebird
Engine: 2.8 Liter V-6
Re: Need help
If it ran with starter fluid but dies without it you don't have fuel. Shouldn't be a spark or compression issue at that point.
Old Dec 3, 2025 | 11:12 AM
LiquidBlue's Avatar
Transmission: MD8
Re: Need help
sure sounds like a fuel problem, check fuel pressure while it is running on starter fluid
Old Jan 29, 2026 | 06:44 PM
Hojon's Avatar
Re: Need help
Got it running tonight. I bought a code reader and when using it, it claimed every sensor on the car including the ecm. Found my old jumper tool and it indicated an issue with the EGR valve. That was new so I replaced the sensor since i had tried to repair it earlier. Bought the replacement off a corvette site. Still couldnt get it to start so i taped off the intake, took the vacuum line off the brake booster, bought a $2 cigar at Caseys and blew smoke into the hose. Smoke came rolling out from under the plenum. Ended up being a vacuum leak. Fixed it and it started up and idled. A little rough but I dont have the timing set yet.
Old Jan 29, 2026 | 07:53 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: Need help
What was leaking under the plenum?
Fred
Old Feb 1, 2026 | 12:25 PM
Hojon's Avatar
Re: Need help
Runner gasket leaking. Had put new ones on and one was damaged. Put new ones on again and torqued properly. AllData says timing is 10 degrees but sticker on car says 6. Set to 6 and reconnected tan/black wire. Purrs like a kitten now. Code reader I originally bought didnt read codes like they said. Told me 8 different codes including ecm bad. Name brand unit (Inova) and I contacted them multiple times but was told theres nothing they can do. Donated to TunerPro and installed on Windows 7 computer and it works great. Showed only one code 34 which pointed towards issue and afr was off.
Old Feb 3, 2026 | 12:32 PM
Fred SS's Avatar
Transmission: 2004r
Re: Need help
Good going Hojo. I had a similar problem, a few years ago, with my runner gaskets.
Fred
Old Feb 3, 2026 | 02:57 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: Need help
Unless you have actual run time the code scanner is almost useless.
pull the control module off and have it tested.
ricknightrider
Feb 17, 2020 07:42 AM
Fonso89
Sep 29, 2017 08:54 PM
knightriderkitt
Mar 25, 2014 03:27 PM
kubinusa
Mar 26, 2010 08:07 PM
DJ Delsym
Jul 22, 2008 04:57 PM
