95 LT1 cam specs for my 69LT1
Old Jan 25, 2002 | 09:52 AM
69TPI's Avatar
After many months and many $, I completed the installation of a 95 LT1/4L60 hydrolic with the original computer, sensors relays ect. into my 69 chevelle SS convertable and after a few years on the road I wish to improve it's performance just dealing with the upper part of the motor without changing the cam (if possible)
Any one of you guys have the specs of the original cam from a 95 LT1 motor. And the rocker ratio.
I'm thinking of buying RR 1.6 ratio, is it going to fit under the original valve covers.
Is there any work to be done with the intake/plenum while I'll get my heads done (pocket porting and 3 angles valva job) beside port match heads/intake.
I already have headers and improved ignition and afpr
Thanks in advance for the time
Old Jan 25, 2002 | 01:53 PM
rezinn's Avatar
IIRC 201/208 @.050 .450/.460 w/1.5 116 lsa
You could port the intake, or look for an LT4 intake to replace it. I guess you already said port though.. I can't comment on all types of rockers, but I know some will since LT4s had aluminum roller rockers.
midge54
Dec 27, 2019 04:14 PM
gixxer92
Sep 1, 2015 04:32 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
midge54
Aug 29, 2015 09:51 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
