EGR or no?
Old Jan 27, 2002 | 02:15 AM
Scarebird's Avatar
Car: 1998 Z28 convertible
Transmission: 700-R4
EGR or no?
Today I yanked out the 85 LB9 out of my 83 Berlinetta. Going into it is a 74 vintake 350 with the 1985 TPI goodies up top. Currently the 350 has a Sealed Power 209/216@ 0.050 cam, ported heads, headers, etc. Should I disable or block off intake heat and EGR function at the head and EGR valve? I live in Seattle, so climate is mild. Will the stock chip (1985) throw a fit? I removed the AIR pump, no SES light, so would EGR removal trigger it?
Old Jan 27, 2002 | 05:06 PM
TA88GTA's Avatar
I is susposed to trigger the SES light but it didn't in my car and in a few other peoples cars that i have talked to.
Old Jan 27, 2002 | 07:06 PM
Guest
Guest
Posts: n/a
I havent run across a MAF car that will trigger a code, even though its supposed to. The AIR you can disconnect and the ecm will not care no matter what else you disconnect.
Theres not much point in disabling the EGR, about the worst thing it does is adds heat to the intake manifold and makes the inside of the manifold messy. Theres a big debate about it increasing performance or not. You want the absolute truth, at WOT it will help with it gone and the crossover blocked, since you will not be heating the intake with exhaust gasses. The EGR will not make your car faster at WOT since its not on at WOT, so dont let anyone con you into believing it will help your car in the 1/4.
Old Jan 27, 2002 | 07:15 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
madmax is right on the money!!!! don't listen to the other idiots who think other wise you can bet they will jump in too!
Old Jan 27, 2002 | 08:29 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
If you do use it, just make sure it's functioning correctly. They can really make a car run like crap when stuck open.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
