TPI Conversion question
Old Jan 30, 2002 | 04:35 PM
89 Drop Top's Avatar
Car: 89 RS Convertible (Original owner)
Axle/Gears: 3.73 With Zexel Torsen Ltd. slip
Hi guys, new member, long time reader here. Gotta quick question, I recently acquired a '85 coupe from a friend of mine, and the car originally came with the rochester compu-carb. I have a 350 TPI engine in my garage that I want to drop into the car, but need to know if the car originally had an in tank fuel pump. I know that I'm gonna have to upgrade the fuel pump, as well at the fuel lines. Your replies are greatly appreciated!! Hope to see some of you at SLP day in E-Town in April!!
Thanks!!
Derrick
'89 RS convertible
'85 Iroc coupe (future road race/drag car)
Old Jan 30, 2002 | 04:51 PM
rhuarc30's Avatar
Just look at the bottom front passenger side of the engine that's currently in it. There's probably a mechanical fuel pump attached there. If not you'll see plate that looks like a rectangle with a pointy top end held on by 4 bolts. Being carbureted it probably was NOT an in-tank unit.
John
Old Feb 1, 2002 | 06:23 PM
Thanks for the reply, The only thing I know is that the car was a 305 carbd. engine with a 5 speed. A buddy of mine gave the car to me, but yanked the engine & tranny before I recieved it. One more quick question though, since it is an '85, and that was the first year for TPI, would if have been pre-wired from the factory for an in tank fuel pump? I know that my '89 RS convert. was pre wired for certian things, like fog lights. I'm just hoping to avoid a fiasco with trying to run wires & such. Again, any insight is GREATLY appreciated!!!!
Derrick
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
