Camaro air lid
Old Jan 31, 2002 | 03:01 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
Camaro air lid
ok has anyone made or tried to make the air box that sits on top of the air filters in a camaro? the part that they now call the air lid on the new z28's.
i'm gonna give it a try here in a few days but i was just wondering if anyone has had experience with it or not.
Andrew
Old Jan 31, 2002 | 04:14 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I don't know of anyone that's tried to make a better id for the filters in a camaro. It's entirely possible that there simply isn't room to make one much better than what you have. Plenty of folks have gone pretty fast w/ the stock piece though.
One area you can improve on is right at the outlet. If you look inside you'll see a ridge that comes up from the bottom right across where it necks down to be round. Getting rid of this is prolly worthwhile if you have some extra time. The easiest way i found to remove it was to simply cut that whole section of the floor out and remade it with epoxy.
Old Jan 31, 2002 | 07:38 PM
Car: 87 IROC
Transmission: 5spd
well i'm gonna give it a shot. i'll probably go ahead and fix the old one and if i get them both ready in time i'll test them both out on the dyno and i'll remove the air filters and then take the air box off and let the MAF sit open and see what it gets.
Andrew
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Wylecoyote08
Nov 6, 2015 03:46 PM
