383 bogs out at WOT
Old Feb 3, 2002 | 03:49 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
383 bogs out at WOT
I just finished building my 383 with a Super Ram setup. The cam is a 222/230 at .050 and I.509" and E.528". I'm pulling about 8psi of vacuum at idle and the best is 11psi. I have a 58mm throttle body and 30lb injectors. Everytime I WOT my car is seems to bog out and blow out black smoke. I had my PROM burned by ed wright. I'm starting to think my computer is running in limp home mode. I am also not getting a reading when I plug the scanner to it.
Old Feb 3, 2002 | 05:27 PM
Blackened's Avatar
If your scanner cant hook up to the ECM then it definetly has a problem. It's either in limp home mode due to a bad EPROM, or the ECM is just bad. Does the SES light come on ? If so... any codes ?
Old Feb 3, 2002 | 06:08 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
I don't get any SES lights, my PROM code is AVXW.
is there a way to test my computer? I think my PROM is a v6 proma but not sure. does ed wrights chip work by flashing the chip and just uses the PROM as a connector?
Old Feb 3, 2002 | 06:46 PM
FstBrd6point3's Avatar
if it is blowing black smoke you could possibly be flooding your engine with fuel, what size injectors are yu running??
Old Feb 3, 2002 | 07:10 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
I'm running 30 lb injectors
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
