Bigger Injectors?
Old Feb 6, 2002 | 05:58 PM
JR4444's Avatar
Bigger Injectors?
I heard that 24# Ford Injectors use different flow charts (or something) Then say Accel 24# ones. So do Ford and GM injectors flow the same, # for #.
Old Feb 7, 2002 | 10:00 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
# for # yes, but only at the rated flow pressure.
I/e Fords are rated flow at 38? PSI, IIRC.
GM's and Accels at 42? PSI.
If you run a 24lb/hr Ford injector at 42 PSI, it'll flow something like an Accel or GM 28lb/hr injector would.
Somewhere you'll be able to find a flow equation to get the exact difference. It's not just a % difference regarding pressure.
Fronzizzle
Feb 9, 2017 09:31 AM
92-Formula
Dec 12, 2015 10:34 PM
BAMiller
Sep 14, 2015 06:38 PM
87hellbird
Sep 14, 2015 05:08 PM
webeeZ28
Sep 14, 2015 12:00 PM
