How does this valvetrain setup look?
Old Feb 9, 2002 | 01:52 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I'm looking at this setup, let me know what you think. If I'm right, this summit TPI cam looks alot like the medium one from SLP? This isn't TOO much cam is it? I don't really know alot about cams, but a good friend suggested the SLP Part# 51006 and this one is similar isn't it? Thanks. It's going into an '87 Z28 305 TPI. Stock, but a flowmaster muffler and tailpipes, TPI airfoil, K&N's. What kind of power might I see from this?
Summit TPI Cam kit
Up to 40 more horsepower for your TPI engine
Chevy: 1985-87 Camaro 305, 350, 1985-87 Corvette 350; Pontiac: 1985-87 Firebird 305, 350, 268/278 degrees duration TPI camshaft kit
Advertised duration: 268 intake/278 exhaust
Duration at .050 in. cam lift: 204 intake/214 exhaust
Gross valve lift: .420 in. intake/.442 exhaust
Lobe separation: 112 degrees
Stuffed in an '86 IROC Camaro with a 305 TPI motor and an ADS Super Chip installed, our TPI cam kit made 40 extra horsepower and knocked almost a full second off the IROC's 0-60 times--and the computer worked perfectly. This kit includes the cam, lifters, springs, retainers, and lube. If your car has more than 30,000 miles, we suggest you add a new timing chain.
One of the highest lift rockers for the street.
Chevy: 1987-up 305, 350 with self aligning, 3/8 in. stud, 1.6 ratio, chromemoly, roller tip rockers
One way to increase power is to increase lift. That's what makes these Competition Cams Magnum steel roller tip rocker arms so popular. They're one of the highest lift rockers you can get outside of racing. And along with the lift, you also get a ball pivot roller tip to prevent valve stem and guide wear.
Sold as a set of 16.
Old Feb 9, 2002 | 02:38 PM
Hg's Avatar
Hg
Car: '87 Z
Also, someone told me that putting in roller rockers requires alot of modification to the heads for them to fit. Is this true? Or are they just like anything else, all you have to do is switch them out? If so, can anyone recomend some good roller rockers? Something that is good, but not too expensive.
Old Feb 9, 2002 | 05:42 PM
Eighty5TransAm's Avatar
DO NOT buy the summit cam, i installed it in my 305 and it kept chewing up my distributor gear, and flattened a lobe. Go for the slp one imho.
Old Feb 9, 2002 | 06:32 PM
Hg's Avatar
Hg
Car: '87 Z
Really? How did you drive it? How soon did this happen?
Old Feb 10, 2002 | 12:29 AM
LottaBallsCamaro's Avatar
You have to use a bronze distributer gear I believe.
Old Feb 10, 2002 | 01:31 AM
Hg's Avatar
Hg
Car: '87 Z
Well, I just talked to a friend, I don't think the summit TPI cam kit will work with my roller anyway, it says for non-roller cam TPI engines. Thanks anyway guys. What about the SLP medium sized cam :
Camshaft Specs: Valve Lift Duration Duration@.050
in: .495" 270 218
ex: .502" 276 224
...and Crane Gold Race Rockers, 1.5's? This sound like a good setup? It OUGHT to be for around 700$... hehehe.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
dusterbd
Sep 29, 2015 08:40 AM
