Fan Turn on 165ecm
Old Feb 14, 2002 | 02:04 PM
jabbott's Avatar
Fan Turn on 165ecm
What wire (color and pin out #) from a 165 ecm turns on the fans. Also is it a + or - trigger.
Old Feb 14, 2002 | 10:40 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
The ECM grounds the relays to activate them. The ecm basically grounds the electronics to control them. Just like the ECM grounds the injectors to complete the circuit to fire them.
On the 165 ECM the fan relay is activated by the ECM grounding the green w/white stripe wire, pin A1.
By splicing into that wire by the ecm and connecting it to a toggle switch that is also connected to ground you can create a nice manual fan switch while the ECM still controls the automatic on/off functions. By splicing into it by the ECM you can keep all wiring inside the cabin and keep it clean.
Old Feb 15, 2002 | 08:15 AM
jabbott's Avatar
Thank You
RazorN8
Jan 7, 2022 11:44 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bryanwood74
Sep 24, 2015 09:50 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
