Swap a LT1 intake for a F-40 Z28 Wing
Old Feb 15, 2002 | 08:50 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
That's right! I will trade a complete (intake and fuel rail) for a
'91-92 F-40 Z28 Wing.
I will even mod the intake to fit on your small block chevy.
E-mail me at John@lt1intake.com
Old Feb 15, 2002 | 09:39 PM
rhuarc30's Avatar
Heh, wish I'd known you were looking, just hooked a buddy up with one, I'll keep my eye out for another one for ya.
John
Old Feb 16, 2002 | 07:04 AM
Engine: 4.0L
Will I have to change the deck the F40 wing attaches to when I remove my old spoiler?
Old Feb 16, 2002 | 08:02 AM
91-ZZ4-Z28's Avatar
I don't think you will have to replace the deck. The wing has 6 studs that go through the deck and 2 more holes for screws that go in from the bottom they are all small holes. The 4 outside holes should be easy just drilling on the edge of the deck. The center 4 will be a little tricky because the deck is 2 layers of steel with about a 3/4in gap and the hole on the bottom side has to be large enough for a 10mm socket to fit the nut on the stud. But if you can get the 2 plastic base pieces for the center supports you can use them as a template to drill from the top and use the hole as a centerline for the roughly 3/4in hole on the bottom. I would drill all you holes test fit it and then have the wing and the deck painted at the same time because you will have the holes from you stock spoiler to fill and to hand paint over bondo is not going to look so good.
Old Feb 19, 2002 | 01:33 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
You have mail.
Old Feb 19, 2002 | 05:10 PM
Engine: 4.0L
Found one, thanks everyone.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
