Pulleys and the belts to hold em up....
I am currently running a smaller belt with the removal of my smog pump. I have stock pulleys on my car. The only thing removed was the smog. If I were to purchase aftermarket march pulleys, or whomever, what size belt is needed to run efectivley on my car....Or can I keep the same belt I'm currently running? Thanx for your help..
Zach
Zach
Guest
Posts: n/a
Check the tech article, the belt size for one type of underdrive is listed. If the manufacturer of the underdrive pulley itself isnt listed there, tell me and I will try to remember whats on the car, or I'll go look for the receipt. Its probably going to be close to the same for other underdrive pulleys though, I cant imagine they are much different in size.
Yea, I will more than likely end up buying them and when the come in, just putting them on, see if they fit my current belt, if they dont, i will try and messure somehow and see what the length is....and go to autozone and get that belt....
bigjay89gta
Oct 15, 2015 08:04 AM
