Swap LT1-LS1 parts into my TPI?
Subscribe
Feb 16, 2002 | 09:43 PM
:hail:
I was thinking about grabing some 24# injectors from a junked 4th gen engine.
I have a 350 with your basic heads,exaust,cam,ect ect...
but the intake manifold up are stock 85 tpi...meaning 19# injectors correct?
I would like to know what I should do to upgrade properly....
looking for the ponys...
the block is a 91 350 out of a 91 Z71...bored over to 355
any info you have is greatly apreciated.
Reply 0
Feb 16, 2002 | 10:36 PM
Since the L98 350 Tpi wasn't introduced until '86, yes the '85 Tpi would have 19# injectors. The L98 350 Tpi engines had 21# injectors so if you plan to run 24# injectors you will need a custom chip to get max performance. I'm running 24# injectors with a stage 2 aftermarket chip that's still programmed for 21# injectors and with my adjustable fuel pressure regulator I can adjust my fuel pressure accordingly so I'm not running rich. Also the '85 ECM was a '160 ECM and was slow from what I hear. Most people usually upgrade those to an '86 or later ECM.
Reply 0
Feb 17, 2002 | 10:43 PM
I have an adjustable fuwl pressure regulator too...and a modified chip...but its not programmed for anything more than the 19s
Im wanting to replace the entire intake and runners...manifold ect...
I was looking at edelbrocks intake and runners...but im not sure..
I have a zz4ish cam...after market iron heads full exaust..lunati through out...
everything on the car has been upgraded except the throttle body..intake and runners..in jectors rails...ect..
hmmm...hmmmmmh.....hmmmm
Reply 0
Subscribe
