What does your T-5 idle at?
Old Feb 8, 2002 | 11:47 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Mines at about 800 rpm. This seems high to me. Just thought I'd ask.
Old Feb 8, 2002 | 04:37 PM
Gary Anderson's Avatar
Free Bird,
Mine idled at 700 when I got it but would fall into open loop if it idled for very long because the O2 sensor would cool off. I raised it to 850 and now it will idle all day in closed loop.
Regards,
Gary Anderson
Old Feb 8, 2002 | 04:41 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Mine idles at 1100!!!
I can't get it any lower.
I am still working out the bugs of the carb to TPI swap though.
Old Feb 8, 2002 | 04:54 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The factory tach says 500, but my Autometer claims it is about 700
Pete
Old Feb 8, 2002 | 07:28 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
500 on the factory dash when shes happy. other wise once in a long time 400-700 when it gets goofy still got bugs!
700 when it first starts.
Old Feb 8, 2002 | 11:21 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
about 750 rpms using craig moates software to check it
will go to about 500 if it sits for a while then it lopes kinda nice
Andrew
Old Feb 10, 2002 | 06:32 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
Mine idled at about 600 rpm.
Old Feb 11, 2002 | 01:30 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
750-850 (before and after cam swap)usually like 1100 when cold. I have a TBI 5 speed that idles lower like 600.
Old Feb 14, 2002 | 06:28 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey zepher have u noticed a big diff from carb to tpi cause i have TBI and its a peice of junk. i am not sure what to switch to though. i know i can do carb and that would prob be better but is it worth the hassle of spendin all that money and findin a whole system for tpi? thanks
Old Feb 14, 2002 | 07:43 PM
camaro6spd's Avatar
well seeing my engines idles but the trans doesn't i will have to say 0 RPM.....the engine on the other hand Idles at 800 rpm in the '87 and the 88 auto idles at 600
Old Feb 14, 2002 | 07:49 PM
camaro6spd's Avatar
well seeing my engines idles but the trans doesn't i will have to say 0 RPMs.....the engine on the other hand Idles at 800 rpm in the '87 and the 88 auto idles at 600
Old Feb 14, 2002 | 11:02 PM
nblanchard's Avatar
I have the 700R4, and it idles at 700RPM, I am going to take it to the dealer and get them to lower it to 550 or 600PRm... it is simple.. but of course they charge an arm and a leg
Old Feb 17, 2002 | 11:09 PM
Car: 89 Formula
Engine: Carbed 5.7
why don't u just do the idle yourself?? its not hard u turn a screw. i would never pay sum1 for that. just get a chilton or haynes manual if u don't know wut your doin. good luck man and don't pay to have that done
Old Feb 17, 2002 | 11:37 PM
nblanchard's Avatar
I disagree with touching that screw, because the IAC ends up over working, and working out of spec. I'd rather the tech guy at the dealer adjust the idle through the computer.... there are certain things I will play with , and certain things I won't. I like my car to idle nice, and it does, so I don't want to botch it up. Thanx for the advice though. I will double check the idle screw adjustment section in it, see if I am missing something
Zane Story
Oct 8, 2015 12:40 PM
Stroopwafel
Sep 11, 2015 06:38 AM
DARKmj16
Sep 9, 2015 04:07 PM
IROCtometal
Sep 9, 2015 10:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
