someone must beable to help me with this parking light problem
Old Feb 16, 2002 | 11:34 PM
chrisfrerick's Avatar
heres whats going on.
1. parking light fuse blows when you turn the parking lights on.
2. parking light fuse does not blow if you turn the dimmer switch all the way down with no dash lights on.
3. turn it up and it blows sometimes along with the gauge light 5 amp fuse.
this is what i noticed on the outside.
turn the left turn signal on and it stays constant in the dash.
with the parking lights on when you turn on the left turn signal the left marker light goes out instead of flashing.
the rear left turn signal never comes on.
i replaced all bulbs still the same.
i replaced the dimmer switch still the same.
i cannot find anything like a remote dimmer switch i dont believe i have one.
what else should i check?
Old Feb 17, 2002 | 01:24 AM
moderator please move this to the tech board
Old Feb 17, 2002 | 09:27 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
have u tried replacing the blinker fuse thingy???
Old Feb 19, 2002 | 09:47 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I think he means the blinker relay.
92camaroJoe
Jul 29, 2023 07:57 PM
tnrednneck
Aug 13, 2015 08:57 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
