just bought a new engine...what should i expect?
Old Feb 18, 2002 | 12:15 PM
i8urrice's Avatar
i just bought a 350 TPI out of a 89 Formula 350..it's totally stock...i'm matching it up to my setup...stock w/ the exception of a flowmaster cat-back...and i also got ahold of an SLP cold air induction kit.......i believe i have 2.73 gears...b/c my rpm's stay lower than anyone elses 3rd gen i know who have the 3.08s....what kind of times can i expect at the track...w/ my 305 tpi i'm hitting consistent 15.640s....??
Old Feb 18, 2002 | 01:08 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
with some gears, low to mid 14's
Old Feb 19, 2002 | 11:55 AM
i8urrice's Avatar
will i easily notice the difference in power from the 350 as opposed to the 305?
Old Feb 19, 2002 | 03:07 PM
i8urrice's Avatar
need to know so i can tell whether or not i got beat for this engine......only way i can tell w/out having to take it apart
Old Feb 19, 2002 | 04:04 PM
Car: 1991 Firebird
Engine: 427 LSX
You are going to put it in before you check to see if it is a 350?? Slow down and explain yourself.
Old Feb 20, 2002 | 08:01 AM
i8urrice's Avatar
bought it from a guy...it was in an 89 formula 350......but w/out taking the engine apart, how can i tell if it's truly a 350 unless i notice a difference in engine power from the 305 that i was running? that's my issue
Old Feb 20, 2002 | 10:36 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Get the casting number off the block.
Some of the newer blocks even have 5.0 or 5.7 cast into the block according to what I've read on this site.
I'd run the casting number to be sure tho.
Old Feb 22, 2002 | 12:16 PM
Car: 1991 Firebird
Engine: 427 LSX
The funny thing is he is serious. Anyhow, just check the casting number like the previous guy said. If the 350 is in good shape it will crush that little 5 liter.
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Sep 7, 2015 01:37 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
pimprs
Aug 24, 2015 11:20 PM
johanlindgren
Aug 16, 2015 12:16 AM
