NEED HELP QUICK: Where to set AFPR????
Old Feb 19, 2002 | 10:21 PM
ImportsRsloths's Avatar
About how far down did you guys turn the bolt sticking out of the AFPR????? was it only a couple turns or what???? Thanks:hail: :hail: :hail: :hail: :hail: :hail: :hail: :hail: :lala:
Old Feb 19, 2002 | 10:32 PM
Guest
Guest
Posts: n/a
Might I suggest a fuel pressure gauge? AFPR's are all different, and the springs in there arent the pinnacle of consistency either.
Stating what AFPR you have would probably help.
Old Feb 20, 2002 | 07:40 AM
BigMike92Z's Avatar
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
i'd highly recommend a fuel pressure guage just to check for yourself. its alot easie rthan guesswork. just go to your local auto parts store, be careful when you open the package, repackage it and return it.
Old Feb 21, 2002 | 12:01 AM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
43 PSI is a good place to start.
Old Feb 21, 2002 | 06:01 PM
wataru's Avatar
The best thing is to use a pressure guage on the stock unit, then after you put the afpr on use that as your base. Slowley increase until you get it right. Hope this helps.
lt1z350
Sep 29, 2015 01:50 PM
hydrolic144
Aug 29, 2015 04:14 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
mustangdmurder
Aug 21, 2015 07:17 PM
